See Pics. tell me what is right or wrong.
Doug Original , 100 , 125 , 582 ![]() ![]() ![]() ![]() West Central Ohio Farmall & Cub Cadet Club https://www.facebook.com/#!/groups/226681087497199/ |
and why is this pump yellow? is it a swap from another tractor?
The filter should say cub cadet on it, hehehe.I don't use cub ones, the case IH dealers have fleetguard# hf 6096.Maybe the pump was a changout or a leftover from the change from IH to CCC.
Ok , what filter is right for my 682
the filter and rag joint almost hit. a paint stick is tight between them
Cub Cadet 923 3014 .I use fleetguard HF6096.lot cheaper.The spacing seems about right.Why did you remove the suction line?
Click here for the proper Hydro Filter..... Filters
![]() Quote:
also put a gasket on the rear cover. the PO and I had words the other day about this not having leaks ![]() the engine sill has a leak ![]() I also did the Breather Assembly and made new gaskets for it. did the left side too.
![]() Quote:
![]() Quote:
![]() Quote:
