Old 03-30-2012, 10:41 AM
Redneck #1 Redneck #1 is offline
Default Cub Cadet 4WD Pictures
I have been asked to share some pictures of the 4WD I built over the past couple years. I have worked most of the bugs out and need to take it back apart and give it a good paint job. That is something I have not been able to pull off, I "good" paint job.
I used 2 Case rear ends with hydraulic motors (high/low range) on each. Turned the front one backwards so the hydraulic hoses pointed back. Made the articulation joint using two bearing hubs from a car. This allows the tractor to both pivot and rotate. Used a motor which runs windows inside a car door connected to the chute rod to turn the chute from inside the cab. Moved the battery under the fender and put an oil cooler under the seat along with the garage door opener attached to the side of the cab. No use getting cold to open the garage door. Put two small fans from inside a computer under the oil cooler to create air flow. The windshield hinges up and is supported by the hood if you need to get to the engine.
The hydraulics are plumbed in series to faciliate actual full time 4WD. Was a concern about back pressure on the first pump, but not a problem so far.
I will try to get some pictures of the thing in motion when I can get one of the kids here who knows how to run the camera and help upload.
Thanks for the interest in this project. My neighbor and I did a lot of sitting, thinking, looking, building, tearing back apart, and building again to get it to come together.
Old 03-30-2012, 10:54 AM
cub71 cub71 is offline
This is the coolest cub I have ever seen I couldn't even imgine build one. My hats off to you!
Old 03-30-2012, 10:57 AM
TheIHMan's Avatar
TheIHMan TheIHMan is offline
That thing is awesome. Excellent job!
Old 03-30-2012, 12:07 PM
That is great! I bet, it's fun to ride.
Old 03-30-2012, 12:31 PM
I agreee with Adam!
Old 03-30-2012, 06:12 PM
EricR's Avatar
EricR EricR is offline
Thanks for the pics and a little of the build story Redneck.
#10-149 with a 38inch deck.
2015 Kubota BX 2670.
Old 03-30-2012, 07:48 PM
robpa robpa is offline
I envy the abilities of some of you guys.
CC 126; CC 122; CC1450; Brinley plow; Brinley cultivators, CC front blade; IH 48" peg tooth harrow.
& 1320 Ford New Holland(EEK!!!)
Old 03-30-2012, 10:31 PM
bocephus1991's Avatar
Very cool! Thanks for the pics!
Brian
Old 04-01-2012, 08:49 PM
cubfan's Avatar
cubfan cubfan is offline
FANFREAKINGTASTIC,AWESOME!!!!!!!!!!!!"
Old 01-27-2015, 06:34 PM
Tacosteelersman's Avatar
Tacosteelersman Tacosteelersman is offline
Old thread revived but I don't care, that is one awesome build. How well has it worked for you after this 2 year old post? Rednecks have some Amazing engineering skills. Thanks for sharing.
3 original cubs
1512 diesel
Ingersoll 3012
John deere 855
