Old 03-30-2012, 01:51 AM
Go_green Go_green is offline
Default Kohler rebuild kits
Hey guys I was wondering if there are any OEM gasket or rebuild kits to be purchased for Kohler K series engines. If not at least key parts like seals or bearings, can they be purchased from a OEM supplier? If I cant get any OEM parts are the aftermarket kits just as good? If anybody has any info please send it my way and pointers on rebuilding a K161 would be greatly appriciated. Contact me through PM
Thank You
Joe
Old 03-30-2012, 09:05 AM
You will need the Kohler manual. It shows how to do a rebuild and has all of the needed specs.
http://www.onlycubcadets.net/forum/s...ead.php?t=4646
Our sponsors at the top of each page should be able to get you set up with a Kohler rebuild kit. I use aftermarket myself, except for the head gasket and crank seals in which I do use Kohler for.
Old 03-30-2012, 09:27 AM
jkier's Avatar
jkier jkier is offline
You will need the Kohler manual. It shows hot to do a rebuild and has all of the needed specs.
The last NAPA head gasket I picked up had the fire ring, pretty much a dead on copy of the Kohler just $4 cheaper.
We'll see how she works once I get the ol 107 runnin
106 Needs a clutch-------107 (Lent to my brother)
123 w/hydro lift & qa36--126 w/creeper and lift
127 restored--------------129 50" mowin machine
129 w/hydro lift-----------147 plow horse w/tiller
149 auction score---------782 KT17SII
Old 03-31-2012, 08:41 AM
nikster's Avatar
nikster nikster is offline
I just go to Napa auto, 5 miles from my house. Better than driving 16 miles to a cub dealer & paying a bit more.
Nik,
Old 04-02-2012, 10:59 AM
Thanks a lot guys I will head to the nearest napa, also pic up a manual
