Old 09-21-2009, 10:15 PM
eastonct124's Avatar
eastonct124 eastonct124 is offline
Default Tires and wheels...
Hi all, I'm new here and my 124 is basically a workhorse...I need to put the widest and tallest big bites on the back (have some mud to drag cut downs through, and barely making it). Do I need 10" wides, and what/where should I order?
Are the carlisle tru.....(can't remember) good?
Thanks
Old 09-22-2009, 07:49 AM
RPalmer's Avatar
RPalmer RPalmer is offline
Are you running wheel weights? I have seen 26" tires on those BUT if you are in mud I think you would tear up your fenders running them.
Old 09-22-2009, 08:56 PM
Don't laugh, but my son (11 yr old)couldn't drag a load of dirt up the hill so I made a quick fix....80lbs of concrete in buckets with pvc to leave holes...so, I have 40lbs per wheel.
I'm usins the stock 6"? wheels, and the stock firestones.
Old 09-23-2009, 08:11 AM
Got 23 /10.5 x 12 turfs on my 1250. Went to a fun tractor pull, stone boat deal and couldn't move the sled at all without weights. I added a LOT of weight and easily pulled 1600 lbs without slipping much. Moral of the story...a bunch- o- weight is a good thing for traction. I had a set of stock simplicity weights, a pair of Case VAC weights, and 1.5 wheels worth of 9N ford weight halves draped over the tunnel cover. By the way...the cheapie trailer I was towing the tractor to the pull with didn't apprecialte all the extra weight either.. :biggrin2.gif:
Old 09-23-2009, 07:18 PM
thanks for the info. can I still buy those rims new?
And nobody has any advice to give on tires? I was looking at the carlise trupower (I think) because they look like they have a real aggresive bite.
I'm haulin cut timber through woods and a creek with a muddy bank...so far so good, but I'm limited to the amount I load on my steel sled becuz traction prob.
Old 09-23-2009, 07:49 PM
Have you checked Tucker tire's ebay listings?? He's got excellent pricing.. I think unless you actually go get professional pulling tires , ag tires will all be pretty much the same for your uses.
I have never actualy owned a pair of small tractor ags, but I do have a set on order from Tucker. 10.50x 12 23 high You also could get 26 12 x 12 ags.. The taller tires will take more power to turn.....
Old 09-23-2009, 07:54 PM
RPalmer's Avatar
eastonct124,
I recommend ags all around. What I have done with one tractor, so far, is to have the tires foamed filled. Here are my perceived benefits. No flats, no leaks, 50lbs extra weight per 23x8.50x12 tire, no load limit. While mine are 4 ply, I could have gotten away with 2. The down side. No cushion from air and when you finally wear out the tire you have to cut it off the rim and clean the foam off. But if you think that you might actually wear out a set of ags you could install a tube first. Then the foam will be stuck to that and not the wheel. I got an extra 25 lbs per wheel up front with 4.80x4.00x8s.
Old 09-23-2009, 09:09 PM
What did you have to pay to get the foam fill? I did have a bud with a Kubota that wore thru the front tires and it was riding around on teh foam until he decided he needed traction..but that tractor was worked hard, broke often, and always put away wet.
Old 09-23-2009, 09:44 PM
What's that foam made out of, lead? You can't get 50lbs. in an 8.50 with washer fluid...
Old 09-23-2009, 11:11 PM
RPalmer's Avatar
Matt I did have a brochure explaining everything but I must have pitched it after I got them filled. I go by their shop on my way to the hardware store. I'll stop and get one. I don't want to misrepresent the product. But really 50# per wheel. I also took their advise and put it in new tires. I'm about ready to get new rubber for my #1 100 and they will get filled also.
