Old 03-28-2012, 08:34 PM
ToddW's Avatar
ToddW ToddW is offline
Default Throttle lever slips out of high when running
Likes to slip fast down to mid range. I cannot see anywhere to tighten tension on the lever under the dash (on a 108)
Any ideas to tighten up the tension on the lever?
Cub Cadet 108, IH snowthrower, IH ?? mower deck
Cub Cadet 1650, IH 44 mower deck, IH snowthrower
1960 Cub LoBoy- yellow roundnose. Fast hitch w creeper and roto tiller, front blade, mower deck and Fast hitch one bottom plow and rock rake
1951 F Cub with Wagner loader and woods brush hog, 152 disk plow and 23A harrow
1953 Ford Jubilee tractor and F100 Pickup
Old 03-28-2012, 08:44 PM
On my 128 there is a bolt and lock nut that holds the lever tight. I was able to tighten the nut on mine till I got it where I liked it.
Old 09-02-2013, 11:13 AM
CLE CUB CLE CUB is offline
My 1650 also does this. Last time I mowed I wedged an empty shotgun shell in there so it wouldn't slip back down. Also couldn't find anything in the service manual. Like DWayne's 128, my 108 has the locknut too. But on my 1650 the throttle unit is pressed together.
-- CLE CUB --
1946 Farmall A
19?? Speedex 840
1971 Cub 108 42" Mower
1975 Cub 1450 Power Angle Plow
1979 Cub 1650 44" Mower & Snowblower
1991 Jeep Wrangler Islander 34" Super Swampers
Old 09-03-2013, 01:03 AM
If they are pressed or riveted together, take it out and using a hammer and a punch on one side and something solid to back up the other side, tap it together to tighten it back up.
Old 09-04-2013, 07:53 PM
Just wondering if that might loosen back up over time especially on a 1650. At certain rpm's it feels like riding my harley. Could you put a small bolt through the hole and squeeze it back together with a lock nut? Anyone try that?
-- CLE CUB --
1946 Farmall A
19?? Speedex 840
