Old 09-20-2009, 10:27 PM
Rhoderman's Avatar
Rhoderman Rhoderman is offline
Default 122 serial number location?
I'm not sure if my 122 ever had a serial plate, or where it was if it even had one. Can anyone tell me where it might have been located? Also, are there any identifying features/differences between the two (?) years it was made?
Mine is very plain-jane. No headlights. No creeper. No supercharger...
What all options were available on a 122?
Thanks folks!
Jim
Old 09-25-2009, 08:52 PM
bigmike bigmike is offline
Jim,
I believe the serial is on a pad on the very back of the transmission....it might be covered by some sheet metal.
Old 09-25-2009, 09:04 PM
It should be on a metal plate located on the top rear or left side rear of the transaxle housing on a small square in the same area.
Old 09-26-2009, 03:12 PM
thadscub's Avatar
thadscub thadscub is offline
there are 2 locations they put the serial #s on 122 one is a plate riveted on a plate on the transmision above the fill plug below the seat or if that is gone should be stamped in the transmision on the left side if you are facing the tractor from behind under the fenders might be coverd in crud
would love to know what the serial # is i also have a 122 made feburary of 1966
thanks thad
Old 09-27-2009, 11:40 AM
Rhoderman's Avatar
Thanks all.
I found this in the manual. Mine doesn't have a plate in the lower location. Hopefully there is one in the other (top of tranny) location. I haven't pulled the sheet metal yet so I don't know.
Old 09-27-2009, 03:13 PM
thadscub's Avatar
they stanped the transmision with the serial # to might have to scrape some crud off of it the serial #on the transmision is under the fender next to the tire good luck in finding it
thanks thad
Old 02-11-2014, 12:13 AM
gsomersjr's Avatar
gsomersjr gsomersjr is offline
This thread may be old but it just saved me so much frustration. I looked everywhere, or so I thought, for the serial number on my 122. I even cleaned the trans with lacquer thinner but nothing to be found. I took the seat and rear sheet metal loose and sure enough there it was on top of the rearend housing. 142413 by the way.
Current: 102 122 SZ60
Past: Original 71 72 73 86 100 102 122 123 124 125 127 129 147 149 169 383 582 682 782 782D 784 982 1000 1050 1100 1200 1204 1210 1250 1282 1415 1420 1440 1450 1535 1541 1641 1650 1710 1711 1730 1806 1810 1811 1860 1861 1862 1863 1864 1882 3185 3200 3205 7265
