Can I buy a voltage regulator, points and condenser from a local auto parts supply that will work in my 123. If so what would the part numbers be? Thanks.
If you buy Cub parts for your Cub you will only spend your money and time once for the repair. Try to stay away from what will fit from the automotive world. You won't regret it.
You can get all of those parts sent to you from our sponsors! =-)
Co-Founder You only need two things in life...duct tape and WD-40 If it's stuck and needs loosening, use the WD-40. If it's loose and it's suppose to be stuck, use the duct tape. |
I was looking at my NAPA parts list and I have part numbers for the points and condensor, but not for the regulator. I just threw in th coil number since it goes along with your other request. Also, I believe the coil is a Kohler brand coil.
Points: 701029 Condensor: 701338 Coil: 4151921S
1980 [COLOR="Red"][/COLOR]482- Stock 1981 [COLOR="Red"][/COLOR]582- Mag18, Sleeve Hitch, Spring assist 1979 [COLOR="Red"][/COLOR]682- Mag18, Sleeve Hitch, Spring Assist, #1 Tiller 1980 [COLOR="Red"][/COLOR]782- Mag18, Sleeve Hitch 1983 [COLOR="Red"][/COLOR]982- Stock, Fully Optioned |
