Old 02-25-2012, 04:38 PM
Fireman72737 Fireman72737 is offline
Default Need drive clutch help
The 122 I just got when i push the clutch in and try to put it in gear it grinds, then jumps in gear and will not stop when the clutch is pushed in. It acts like the clutch is stuck together. It has been sitting out side a while before I got it. Any ideas how to get the clutch to slip and un stick. Also the "O' I got does the same thing.
Always Looking for More!
Old 02-25-2012, 07:00 PM
4SPEED's Avatar
4SPEED 4SPEED is offline
my 582 was like that. the clutch was rusted and the teaser spring was broken.
Doug
Original , 100 , 125 , 582
Old 02-25-2012, 07:11 PM
Push the clutch down and set the brake lock,take off the clutch cover and take a putty knive and pry it between the clutch plate and the clutch disc,repeat the process on the other side.Like 4SPEED said,a broken teased spring will cause the same symptons.
