Old 09-10-2009, 01:47 PM
MFP8055 MFP8055 is offline
Default Cub Cadet paint
Almost ready to spray the 1650, and I just bought a quart of the yellow and white from my local dealer. The white is p/n 759-3264, and the yellow is p/n 759-3263. Has anybody shot this stuff through an HVLP gun? What thinner did you use, and at what dilution. The base solvent is a mixture including xylene, so I may use straight xylene as a thinner. Mineral spirits are close too. My dealer had no advise on this. Also, are these the correct colors?
IH 1650, CC 1210, 1610 and Bolens 1257
Old 09-10-2009, 06:16 PM
metalrain metalrain is offline
MFP;
I've used an oil base paint thru an HVLP gun. It will work, but its not the guns strong point. Its been a few years but i remember thinning it with mineral spirits almost a 100 percent or more, but xylene will work (just a different flash rate)...spray it just like enamel, tack coat, 2-3-4 color coats (what ever it takes to full hiding)...then a mist coat....the old non hvlp guns spray it much better, alot more atomization with HVLP. Since my first cub oil base paint, i've switched to basecoat clearcoat....tons easier, and it won't fade after a year in the sun.
Metalrain
Old 09-11-2009, 02:39 PM
Cub124 Cub124 is offline
Those are the correct colors. When i painted mine i just used mineral spirits for the thinner.
Old 05-13-2010, 04:50 PM
thenrie's Avatar
thenrie thenrie is offline
Hope no one minds me reviving this thread. I bought quarts of Cub Cadet yellow and white paint and was quite surprised to find absolutely no thinning, painting, recoat, nor other information on the cans. Obviously this paint is repackaged for IH. Does anybody know who makes the CC paint?
I am assuming it is an enamel, rather than a lacquer...right? Doesn't say on the can. I'm going to try thinning with Mineral Spirits.
By the way, thanks for the painting tips.
Tony
Stafford, VA
1650, 682...
Old 05-13-2010, 08:28 PM
Mountain Heritage's Avatar
Let us know how you make out with this. A before and after picture would be the cats......you know. :biggrin2.gif:
Old 05-13-2010, 09:48 PM
murphycc
Guest
Posts: n/a
If it's an alkyd you want to use Naptha and NOT spirits. Alkyd is a mistake but it's your mistake.
I cannot for the life of me understand why you guys insist on not using an acrylic....I just cant......
Scott
Old 05-13-2010, 09:53 PM
jbollis's Avatar
jbollis jbollis is offline
I have done some looking for a suitable paint for my 1872 when its time. I think I will be using the Hardnose line from POR-15.I know the color will not be a perfect match to the factory ones, but they look close enough for me. Anybody know anything about this stuff ?
Joe
Sold everything but one.
Old 05-13-2010, 10:05 PM
Tony-
I'd try 8 parts paint to 1 part naptha and see what the consistency looks like. It should be fairly thin, but not so thin that it runs off the part that you paint. Some experimentation may be necessary.
Old 05-13-2010, 10:10 PM
murphycc
Guest
Posts: n/a
Originally Posted by metalrain View Post
MFP;
Metalrain
Xylene is a 'hot' solvent.....you gotta watch what solvents you use and what product you apply over other products.
For example, you spray a hot finish over a laquer based primer you are gonna have one big freakin mess.
Scott
Old 05-20-2010, 11:37 AM
thenrie's Avatar
Well, all that is good info, with which I'm not totally unfamiliar, however, I'm still hoping somebody can tell me whether the CC paint, the stuff we buy canned from IH, is an enamel, alkalyd enamel, or something else. There is absolutely nothing on the cans. Apparently it doesn't require any hardener, and others have said they used mineral spirits to thin it, but they didn't say how things turned out.
The label only indicates a health warning that it contains xylene. I don't have any xylene, but as I recall, xylene is an enamel reducer, so I'll try mineral spirits and see if that works before I try anything else.
It will be my first try on an HVLP gun (and a cheap one at that), so we'll see how things go and I'll report back.
Tony
Stafford, VA
1650, 682...
