I found a 1650 running and in good shape has been used to mow up until last year. Im going to go see it and may buy but was unsure of price. This will be my first wide frame and have been reading a lot about them and the 1650's. Future plan for this tractor is to build a loader for it. They are asking $600 for it. What do y'all think?
Always Looking for More! ![]() |
I'd say it's worth that in my opinion. I see 1650's bring that and more as long as the paint is nice and no real issues. They have hydro lift, lights, and a 16hp Kohler so them and the 1450 are usually worth a little more than the other QL's. Check the motor mounts (see if motor shakes around while its running or not). Even if it does shake some, not impossible to put new mounts in.
Preserving history... one Cub at a time. |
Too many variables to give you an accurate answer.
This guy said the tractors ran, they wouldn't when I got there, I got all three for about half the price you stated!! ![]() Other people ask $2500 for them!!?? ![]() Use your best judgment and bargaining skills when you get there. ![]() |
Thanks for the info. My repair skills are pretty good and the mower by the pictures i saw looks like it has spent it life inside .
The main issues with QL's are, worn out engine ISO mounts. Worn out drive shaft components. Worn hydro trunion. All of these issues are not really big issues to deal with mechanically, but it can add up $$$ quickly. But, once mechanically sound, it will outlast anything that is sold in box stores today, and probably give good service for the next 25-30 years with good preventative maintenance before needing major service again. Also it will still be cheaper in the long run to put the $$$ into it than to purchase a new $2k or $3K unit that will be worn out in 5 years or less.
DWayne 1973: 128, ag tires, 3pt. lift, spring assist, lights, 42" Deck 10" moldboard plow 2016 XT1 42" deck 18HP |
![]() Quote:
Thanks for the heads up on the 1650. I like the look of it but I thought $600 was a little much. He did not sound like he would give much on the price either
If it seems too good to be true, we all here have found out that the right one always pops up eventually. You might give the WF's 1X8/1X9 and the 82 series GT's a good looking at. The 82's run Kohler Twin cylinders and are smooth running. The WF's are easy to work on and maintain.
The longer he sits on it the cheaper it'll get unless he gets it in running order and address the ISO mounts and drive line to make sure there are no issues there.
