Old 02-13-2012, 06:30 PM
Daniel.Donaldson Daniel.Donaldson is offline
Talking My 128!!!
This is my 1972 Cub cadet 128. it has external disk brakes and no creeper. I was wondering what I should do about the rusted battery tray? Also was wondering if the clutch cover was correct for the model?
Old 02-13-2012, 06:35 PM
Nice find! Did it come with an engine?
Old 02-13-2012, 06:38 PM
There was no clutch cover on that model, it had side panels, little ones!!
Old 02-13-2012, 06:56 PM
IACubCadet, yes, it came with a K301A engine that was worn out along with one other K301A in the same condition. Been thinking about rebuilding one of them, but not sure yet. CADplans, thanks! I was wondering what they look like. Also wondering if anyone knows how to get the rusted foot rest pads off?
Old 02-13-2012, 07:26 PM
Saltydawg's Avatar
Saltydawg Saltydawg is offline
If you have a welder handy, spot you some hexnuts on top of the trusshead screws. If you dont you can take a cut-off wheel and deepen the slots so you have more meat to get a grip on.(no pun intended)
72 Cub Cadet 109 S/N 435384
^^^undergoing a refurbishment^^^
71 Cub Cadet 149 S/N 410929
Old 02-13-2012, 07:37 PM
Youll like the 128. They are a very handy tractor. Really easy to work on.
Old 02-13-2012, 07:48 PM
TheSaturnV's Avatar
Daniel, if you have a welder you can tack a piece of round bar (about the size of an old Cub driveshaft) onto the top of the frozen foot pad screws. This will give you tons of leverage to back them out. Spray PB Blaster in the screw areas (you can spray them from below too) for a few days beforehand, and make sure you clean up the bar and bolt head before welding.
Mine came off with just PB Blaster and a hefty flat bladed screw driver aided by a wrench for more torque.
Old 02-13-2012, 07:59 PM
Congrats on the 128 score!
Old 02-13-2012, 08:01 PM
Those are easy to remove with either an impact screwdriver or by heating the nut plates on the back dull red with an oxyacetylene torch.
Old 02-13-2012, 08:12 PM
Thanks for all of the advice guys! But now, does anyone know how to solve the rusted battery pan problem? will regular sheet steel weld into place?
