Old 02-11-2012, 10:21 AM
ab147's Avatar
ab147 ab147 is offline
Default New to me snow thrower
I bought 2 149's last spring, one's a parts tractor the other a runner with a deck and snow thrower. I have an f350 with a plow that I use here at home because the farm field across the road sends all its snow into my driveway. anyway I hooked up the thrower on the 149 acouple of months ago, and haven't got a chance to really use it as our winter here in michigan has been non existant. We got hit last night with a good snow, and high winds and ended up with a 4-5ft drift in our drive way. I'm on cloud nine. I went out this morning and got the 149 going, and attacked the drifts only to have the blower throw snow all over the front of itseslf and block the snow from coming out of the chute. After looking at the owners manual here on OCC I notice that I don't have a deflector guard. Is this necessary? Before it plugs up it throws snow pretty good. The faster I drove the tractor the better it worked, I thought it would be just the opposite. But it would still plug the chute. Maybe I need more rpm's out of the engine, would this help? Thanks for any and all comments.
147 w/mower deck, plow and rototiller owned for 22 years
149 new to me in 2010
2 more 149's with a a42a snowblower new to me in 2011
Old 02-11-2012, 10:38 AM
You should always have the engine running at max RPM's.
Some pictures of your Cub and blower would be good to see.
Old 02-11-2012, 10:51 AM
The engine needs to be running at 3600 rpm, the belt needs to be tight, and the chute needs to be rust-free. Graphite paint helps a lot. The chute angle should be set about halfway between the two extremes. Also, you must vary your forward speed such that the engine is just tugging on the governor; any faster or slower than that and you won't throw snow as far. In a 4' drift you will probably just be crawling along.
Old 02-11-2012, 11:30 AM
Full RPM and keeping the auger loaded will make a single stage thrower work the best.
I spray my chute with generic PAM cooking spray.
Works for me
Old 02-11-2012, 08:02 PM
cmatthew's Avatar
cmatthew cmatthew is offline
wet n heavy or dry n light snow are two totally different beast also. working with varying speeds and whether your using the whole or half width of the auger will make the difference too. seat time in the snow is the best remedy. drifts are pretty packed so it will be slow goin. have fun
Old 02-11-2012, 08:50 PM
4SPEED's Avatar
4SPEED 4SPEED is offline
get a blade,,, you'll get a lot less snow in your face that way.
Doug
Original , 100 , 125 , 582
Old 02-11-2012, 09:58 PM
PaulS's Avatar
PaulS PaulS is offline
4speed I agree to a point but he is talking drifts and in my experience a blade can only shove so much snow till there is no place to shove it. A proper working blower or thrower will actually move more snow out of the way albiet at a slower pace.
Old 02-12-2012, 10:53 AM
ab147's Avatar
I hope we get more snow for more seat time, I'm going to increase the rpm's, clean out the chute because it's got some rust on it, then hope that I can get some distance like Jeff in Pa is showing in his avatar.
4speed, Love your other hobby, just sold a 79 like yours last summer, it had black int. auto trans. 400. Only car I have left is a 73 4-4-2 clone. Big block 4 speed.
Old 02-12-2012, 11:23 AM
You have to run these single stage to the Max 3600 rpm.A tight belt, clean auger and chute,and a can of Pam did it for me.
Up to 534 and counting...
Old 02-12-2012, 04:37 PM
Great vid, Lew! I enjoyed it.
