Someday I want to make my 108 a hydraulic lift and put a 14 horse in it to make my ultimate plow tractor. Id like to put the blue or red clutch spring in the clutch just to make it a little tougher but my 108 has a creeper. So the question is, should I leave the creeper in so I can keep the 108 loaded or will the 14, heavy clutch springs and plowing kill the creeper?
Nick. ![]() Cub cadets 100, 125, 86, 108, 109, 128, 129, 129, 149, 149, 169, 1450, 1650 and a handfull of parts tractors. #40 box blade, ih back blade, rear ih rock rake, #2 cart, windbreaker soft cabs, windbreaker hard cab, cozy cab, kwikway loader , wards corn planter, brinly plows, culitvator, rear blade, disc and the usual decks, snowblowers and 2 tillers |
If you are making a dedicated plow tractor, I'd leave the creeper out since you have no use for it. The stronger spring will probably not be kind to the creeper bearing. I would use a red spring and replace the roll pin that keeps it compressed with a locking collar so you can adjust it. The red spring is 800 lb/in, but you don't need 800lb...even my 582 has it only compressed 3/4", giving it 600lb when engaged, and the clutch never slips, and the pedal force is still pretty low.
i agree with matt. i have a 108 with hydraulic lift with a 12 hp that i use for plowing. stock spring with a washer behind spring, new disk and plates. hasnt slipped yet. nice tractor 4 plowing.
