Old 01-26-2012, 11:35 AM
ndanger ndanger is offline
Default Hydro tube O-ring
Here's what might be a dumb question. I am going to replace some seals and the Hy-Tran in my 1650 because the tube between the transmission and the main drive housing has a seal leak at the transmission end. I am trying to gather all the parts I need to fix this and replace the Hy-Tran BEFORE I tear things down, since this is my working tractor and I don't want to have to run around or wait for parts while it is down. My question has to do with the O-rings that seal the tube connections: the parts manual lists it as 'O-Ring, 3/4 x 15/16 x 3/32". I've always seem o-rings specified by ID and material thickness.
To what does the third dimension refer? Or, alternately, to what do each of the dimensions refer?
Cheers,
Dave
1976 1250 Quiet Line/44" Mower Deck
1976 1650 Quiet Line/50" Mower Deck/42" IH Blade
Agri-Fab Utility Cart
Old 01-26-2012, 11:44 AM
ID x OD x Dia
Old 01-26-2012, 11:48 AM
Thanks.
Three dimensions seems redundant to me (but I'm a sparky and not a wrencher).
Cheers,
Dave
Old 01-26-2012, 12:20 PM
Maybe this will portray it better....
Old 01-26-2012, 02:10 PM
Yep, it's clear. I still think only two of the dimensions are needed to fully specify the part's size. But, hey, you learn something new every day!
Thanks!
Cheers,
Dave
Old 01-26-2012, 03:10 PM
One day an engineer went to the tool room needing a special washer.
He quickly jotted down the dimensions.
1/2" OD
3/4" ID
1/4" thick.
He came back 2 hours later, the tool maker handed him a small handful of chips!!
True story, I was there to see the look on his face!! I was much nicer to the tool makers after that, I did not want that to happen to me!!
Old 01-26-2012, 03:52 PM
You have to have all three (3) dimensions for proper fit.
There are several O rings available with the same ID & OD, but the diameter of the ring are different. SO....it is important to get the correct diameter NOT just the ID & OD or you will have a leak.
