Old 01-24-2012, 02:51 PM
Tater305's Avatar
Tater305 Tater305 is offline
Default Kohler 12hp problem
Alright guys I got a 12hp kohler that refuses to run so here is what it is doing. It is getting spark, the carb is getting fuel but the plug is dry so the motor is not getting fuel, now it will run if i shoot some gas in the carb but thats it then it will die and wont fire back up. So what am I over looking? I am not the biggest kohler fan and this one is trying my patience so anything you can do to help will be appreciated. thanks
Old 01-24-2012, 02:54 PM
Sounds like lack of fuel.
You make no mention of the Cub Model this Kohler is installed in. Might help if we knew that to further expand.
Old 01-24-2012, 02:56 PM
Pop a Briggs in the tractor if that's what makes you happy,
or,
rebuild the Kohler carb..
Old 01-24-2012, 03:06 PM
Tater305's Avatar
sorry I must have missed that the motor is in a 129 hydro
The only briggs I have is a twin 18hp I would have to chop up the frame too much. I did rebuild the carb and it worked fine when I drove it around just after I parked it it started this problem cause I needed to move it and I was going to use it for snow duty while I fix the oil leak on the M18
Old 01-24-2012, 04:05 PM
Might check this to see if the screen is plugged....
Old 01-24-2012, 04:49 PM
Tater305's Avatar
ill check the screen but it has good fuel flow, that was the first thing i checked but this has me stumped
And on top of that the one and only key I have for it just broke so now I have to get a copy made....luckily my buddy has a couple cubs and I can use his key to get a copy made
Old 01-24-2012, 05:42 PM
If you're getting fuel to the carb, but not in the combustion chamber when you crank over the engine, then one or more passages in the carb are blocked, and it's time for a thorough cleaning and rebuild.
Old 01-24-2012, 08:26 PM
Tater305's Avatar
I did that when I first got the tractor and it worked fine but I guess it has picked something up again. I just wanted to use the tractor some more I just got it last week and drove it around the yard once and everything worked fine but I guess its back to a carb cleaning again.
Old 01-25-2012, 07:36 AM
Welcome to the world of ethanol. If it sat with gas in it for any length of time I'd bet the carb is nasty inside.
Old 01-25-2012, 08:37 AM
If you have good fuel flo @ the carb, you might try taping on the float bowel with a screwdriver handle because it sounds like maybe the needle valve is stuck closed, it is not unheard of and sure is easy to do.
Next would be loosen the bowel and see if fuel flows from it.
You do have a "no fuel" problem from the sound of your description.
