Old 01-14-2012, 08:58 PM
silverthornethan silverthornethan is offline
Default 108 puller
I am building a 108 puller. i have a rear end out of a 71 and i was thinking bout switching them. Which would be better for just strictly sled pulling?
Old 01-14-2012, 09:58 PM
brucer95's Avatar
brucer95 brucer95 is offline
There shouldnt be much difference. The 71 may have the 17 tooth 2nd gear which can have advantages in the stock classes "at times" but can also hurt sometimes. My tractor is a "stock 12hp" and out of maybe 25 passes i couldve used the 17 2-3 times. I dont know what class your thinking of joining but stock is the only class which any of this will matter, the hotter classes only retain the stock housing and not much else.
129 Plower; 72 pile;122 daily driver, 2-42inch blades 42 inch deck- 06 GMC 1500 4wd- 1964 farmall 706
Old 01-15-2012, 03:14 AM
I am going to pull stock class. I already have the rearend so I think I'm gonna go ahead and switch it
