Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines
Old 01-10-2012, 08:10 PM
jaredwaltz jaredwaltz is offline
Default Advice for 16hp
Hey all, I'm having some trouble keeping my 16hp from running smooth when i throttle it up. It will sit and idle just fine. It is practically brand new minus a few pulls I entered. I used this motor last year for the pulls, Drained the fuel -then sat for 10 months. I have an old fuel pump on it which was used, which makes me think it may need a new diaphragm. The last idea I have is the crank.
When I put the motor in the tractor and fired it I noticed the driver was off kilter, then worked its way inline with the crank. Would this have cracked the crank? Thanks in advance for any advice.
Old 01-11-2012, 07:51 AM
mickb72 mickb72 is offline
Default 16hp
Hello, Check your grounds and try another condensor. Try a gravity fed fuel tank. I have no idea on your off kiltr, maybe a pilot bushing wore out? Mike
Old 01-15-2012, 07:55 PM
4SPEED's Avatar
4SPEED 4SPEED is offline
my 16hp BS did the same. I rebuilt the fule pump and it runs so smooth now. put a kit in the carb too, sence it was off.
Old 01-19-2012, 09:33 PM
well I may go the fuel pump route since I don't know any history of the one that on it. I checked my clutch driver to make sure it was in line w/ the crank -and it was so that's ruled out.
