Could i put an horn on my cub cadet?
Yes you can...
It was an option. I had one on a 122. Beep beep
is there any way to buy just for the cub cadet like they did back than.
You won't be able to any more as they are no longer availible
any suggestions on what horn to get would a cheap harbor frieght horn work?
![]() Quote:
I had a air horn on my 128 from Harbor. It worked great i hid it in the dash. I toke it off because of my headlights.
1971 128,3pt,ags,rebuilt motor,headlights 1988 1812,dual ports 1966 122,creeper,3pt,ags,sa,headlights,restored 1st place at RPRU 2013 1966 123,3pt,brinly spring assist 1973 108 1968 125 Attachments:QA36A,wfblade,2 nf blades,brinly disc,a cultivator,plow,homemade wrecker boom with 2000lbs winch,ih weights,50lbs weights,2IH windbreakers |
Here you go.This is one that came out of a 102.The one in the 122 used the same horn,brown wire ,and chrome push button.Both were mounted in the same spot,so I am pretty sure it was done by a dealer...
do you still have those horns?
BEEP. BEEP,no BEEEEEP!!!
