Old 01-03-2012, 02:19 PM
Daryl Daryl is offline
Default Can someone explain v-regulator operation ????
Thanks to all for the info on this site...I have found it helpful. My question is how should the voltage regulator work? The S/G is in the shop right now, and I haven't got this old 124 to run yet. ( plenty of voltage ) I do know that I have no solenoid movement in the the reg. when I turn the key. Should it do anything? I was hoping someone could explain the proper sequence of events for the reg. Also, the middle terminal has continuity to ground all the time ... doesn't seem like it should.
I have looked at allot of the pics on the site...I have a resistor before the coil and I don't see any others like this. Should it be removed?
Thanks again...Daryl -the new guy.
