Old 12-13-2011, 08:44 PM
brentwd's Avatar
brentwd brentwd is offline
Default 129 Axle Pivot
I have recently purchased a 129 and the PO mangled the axle pivot. The holes have been enlarged to the point of having to install a bushing. I have 1/4 inch thick washers that can be drilled to 3/4 ID. The question is should I install a bushing and pin in the axle or should I use a hardened bolt? Out of all the cubs I own it seems the axle seems to spread the channel out.
