Old 12-03-2011, 12:08 PM
72-149's Avatar
72-149 72-149 is offline
Default will a NF voltage reg work on a WF
I was wondering if a NF voltage regulator work on a 149 ?
Old 12-03-2011, 12:53 PM
72-149's Avatar
I figured it out. Just put a jumper wire from B & L together because L doesn't get used on the WF
Old 12-03-2011, 03:25 PM
Do NOT jumper the "L" terminal to anything, just leave it connected to nothing. You will probably fry something if you jumper it to the "B" terminal.
Old 12-03-2011, 11:57 PM
72-149's Avatar
They both end up at the same spot down line if you look in the wiring diagram for the NF & WF, it gets power,s o thats why I did it. It started fine and is charging.
