Old 11-25-2011, 04:22 PM
jim55 jim55 is offline
Default help with charging
Can anyone tell me how you can tell if the generator is bad? It will start fine but when I put a test light on the generator, on both poles, at a high idle, it is very dim. On either post you can barely see the light. I just got this tractor and it had a new wire harness on it. Everything seems to be alright on it. Thanks for any help anyone can give me.
Old 11-25-2011, 05:17 PM
Use a multimeter.
Check the voltage at the battery with the tractor off.
Start the tractor, check the voltage at the battery, the voltage should be higher when running at a speed well above idle.
Let us know what you find.
Old 11-25-2011, 07:20 PM
i switched generators and that didnt work like i said that i just got this tractor and its got a new wiring harness on it i checked all of the connections to make sure that all of them are going the way they should be the gentleman that i bought the tractor from put a NEW VOLTAGE REGULATOR ON IT AND THE BATTERY IS NEW IM NOT SURE WHAT TO CHECK NExt help.
Old 11-25-2011, 07:35 PM
CHWNY's Avatar
CHWNY CHWNY is offline
you need to polarize the regulator ...With everything connected , fully charged batt, key off, take a jumper wire and arc the Batt. terminal to the Gen. terminal or batt. to A on S/G. you just need to make a spark not a connection. any time the batt. goes dead or disconnected for a short time this should be done ...check for charging w/ volt meter
Clay
Old 11-25-2011, 07:36 PM
This link may help you trouble shoot your issue:
http://www.onlycubcadets.net/forum/showthread.php?t=18
Old 11-25-2011, 07:54 PM
Thumbs up
thanks guys i will try that tomorrow
Old 11-25-2011, 10:16 PM
No need to polarize a starter/generator charging system, as it polarizes itself the first time you turn the key to start it.
With the tractor running, temporarily ground the F terminal on the S/G. If the ammeter pegs (if equipped, you didn't say what model tractor this is) to the charge side, the problem is the wiring or voltage regulator. If it doesn't, then it's the S/G. If it doesn't have an ammeter, then look for a voltage jump across the battery when the F terminal is grounded. Don't leave it grounded for very long or you'll burn up the S/G.
Old 11-26-2011, 08:13 AM
its cub 72 with 7h motor
