Old 11-23-2011, 08:20 PM
jeffscub's Avatar
jeffscub jeffscub is offline
Default question on tranny fluid
According to the chart, it says gear drive O-1x4/5 uses hytran or sae30 oil and the 1x6/7 -82 uses hytran only. Can you use 30 weight in the 1x6/7-82 also? If not is the hytran the same hytran used in the hydrostatic? Thanks Jeff
'72 108 w/ 38" HIGH speed deck, '77 1200QL w/ homemade grader blade, '79 1450 44" grass tamer, '70 sears super 12 w/ 3pt , 19?? 100 w/ extra toys, 69' economy powerking 14 horse w/ FEL, 65' economy powerking w/ toys, 1982 allis chalmers 716
Jeff
Old 11-23-2011, 09:05 PM
bocephus1991's Avatar
Heah Jeff, If it says you can use HY-Tran that's what I would stick with. That's all I have ever used in my 1200 and in dads hydro grasshopper. Think that's what IH recommended in all their garden tractors gear drive and hydro.
Brian
Old 11-23-2011, 09:29 PM
Yep, better off using the Hytran in both gear and obviously hydro units. It is the water displacement properties that make it the best to use.
Old 11-23-2011, 10:32 PM
You won't go wrong using Hy Tran.
Old 11-24-2011, 08:35 AM
CHWNY's Avatar
CHWNY CHWNY is offline
Default $$$
You can't go WRONG using Hy-tran BUT You might go BROKE!! Shop around!! Try buying from a larger equipment service shop bring your own clean container. My local CC dealer gets $24.99gal and $16.99 for hydro filters. For the hydro guys MY research found Fram PH2844 ($3.19 at Auto Zone) to have the same CC full flow filter requirements, Please check for your self.
Clay
Old 11-24-2011, 08:57 AM
That Fram filter is an oil filter...don't use it. You need a hydraulic filter. THey are not the same. There have been Wix, Fleetguard, and NAPA numbers posted in the past that cross to the OEM filter.
Old 11-24-2011, 10:20 AM
CHWNY's Avatar
Not to be CROSS but Wix 51410 And Napa 1410 BOTH CROSS REFERENCE to Fram PH2844. I don't have the Fleetguard # to cross over. I would recommend using what ever you feel is best for you! If your tractor is under any warranty always use factory parts. I feel Hydraulic fluid is oil and I will Use the Fram Filter. BTW I don't use Hy-Tran, I use a quality product that meets the Sunstrand requirements. I change my oil and filter more than recommended. Time will tell!! AS I STATED Please check for yourself!!
Clay
Old 11-24-2011, 11:22 AM
Hydraulic fluid and engine oil are similar, but an engine and a hydrostatic transmission are not. Hydraulic oil filters trap much finer particles than an engine oil filter. The tolerances on the hydro pump are much tighter than on an engine, so the cleaner it is kept, the longer it will last, hence the need for a hydraulic filter and not an engine oil filter.
Just because they cross to each other does not mean they are equivalent. They have the same overall size and mounting interface, but the Fram filter number is for an oil filter, and the WIX/NAPA numbers you posted are hydraulic filters. There are numerous oil filters that'll physically fit, and probably cross reference to the correct filter, but they are not a suitable replacement. I have also heard of quite a few people having problems after using the wrong filter (i.e. an oil filter), and I have also had hydro problems on tractors where Fram and filters were used in place of the correct hydraulic filter.
I can also tell you this has been beaten to death over the last decade on multiple CC forums, with one member going so far as to buy several different 'equivalent' filters and cut them all open to see how well they were constructed. The result of that was the creation of this acceptable cross-reference chart. They went quite a bit further than it appears you did with your research to determine what filters are acceptable substitutions.
Old 11-24-2011, 01:15 PM
greasemonkey greasemonkey is offline
i got 2 gals of hydrualic trans fluid at tractor supply for a bit more then the cost of one quart of hytran..... says on the bottle it meets requirements of hytran.
Old 11-24-2011, 02:58 PM
I pay $65 for 5 gal of hytran at my dealer.
