Old 11-19-2011, 07:42 PM
OverKnight's Avatar
OverKnight OverKnight is offline
Default Broke my key...
and it's the only one that came with the tractor when I bought it. Never got around to getting a spare made, dangit... Anyway, how can I get a new one made? Can a locksmith cut one based upon the numbers on the old key, or can I order one from somewhere?
Many thanks.
Old 11-19-2011, 07:58 PM
CHWNY's Avatar
CHWNY CHWNY is offline
Many thanks.
I will come down and get that dumb tractor out of your hair. Just need directions from Albany, NY
Can you get the end out? If its a cut key,You might better just get a new switch.
Clay
jbrewer's Avatar
jbrewer jbrewer is offline
Default Been there
I left mine in the ignition when I hauled my 123 home and it fell out on the freeway somewhere. Doh!
Fortunately, there's not a lot of different keys. I got one listed for my 123 on Ebay and it worked fine. Perhaps some of the fine sponsors of the forum have them also!
John
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 11-19-2011, 08:05 PM
A toggle switch and a push button,.................
How old is it??
Old 11-19-2011, 08:15 PM
72-149's Avatar
72-149 72-149 is offline
How old is it??
thats the only way ,dont have to worry about a key ,toggle switch for power race car rubber push button !!!! "DONE " works grate did it on my 149.just find the power wire to the ing. & the one to starter !!
Old 11-19-2011, 08:31 PM
OverKnight's Avatar
I know I could replace the entire switch, for about $40.00. But the switch is fine. I'll give the local locksmith a call on Monday, but I was just wondering if anyone else has had this problem, and if they were able to get a replacement key.
Old 11-19-2011, 09:00 PM
If I remember correctly, the keys from my 123 was broken off and all I did was worked it around and finally got it out, then used one from a 106 to replace it.
I used one from my 102 to replace the one from my 100, so they all seem to work from one to another, so you should be able to get a new used one or get one from someone and try it, then just get a copy made.
Old 11-19-2011, 09:04 PM
OverKnight's Avatar
So you're saying all Cub Cadets they all have the same keys?
Old 11-19-2011, 09:09 PM
Well just speaking for what I've done, that the 123 and 106 were the same. As well as the 102 and 100.
Old 11-19-2011, 09:13 PM
jbrewer's Avatar
For a given model, yes!
http://www.ebay.com/itm/Cub-Cadet-IG...item2c60cf1f3e
John
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
