I have a 69 cub 147.
apparantly the previous owner repainted part of the machine and I can't seem to be able to find the serial number tag. Is this number stamped in the frame? If so where can i find it. Thanks for any help you can give.CUBSFOREVER!!! |
I might be wrong here, but I believe your serial number tag is rivited to the rear of your transmission. If you look at the tractor from behind, look at the bottom left of the diferential and I think it will be there.
AJ
1980 [COLOR="Red"][/COLOR]482- Stock 1981 [COLOR="Red"][/COLOR]582- Mag18, Sleeve Hitch, Spring assist 1979 [COLOR="Red"][/COLOR]682- Mag18, Sleeve Hitch, Spring Assist, #1 Tiller 1980 [COLOR="Red"][/COLOR]782- Mag18, Sleeve Hitch 1983 [COLOR="Red"][/COLOR]982- Stock, Fully Optioned |
I have a 123, my serial number tag, looking from back,riveted to trans,on left hand side.vertical up and down positioned.Phil.
Thanks for the information. It is a big help. Was able to locate it easy.Thanks again.
CUBSFOREVER |
