Old 11-13-2011, 08:16 PM
gillis51 gillis51 is offline
Default Model 149 negative camber.
I have too much negative camber on my model 149. Any way to adjust it other than a length of pipe on the spindle and lift?
Old 11-13-2011, 08:19 PM
That's about the only way.
Old 11-13-2011, 08:55 PM
Got a picture? I think it would be pretty hard to bend the spindles so bad as to create negative camber on any WF model (without breaking the axle, too), as the spindles are pretty strong in that respect compared to the NF models. If they are bent and you need to bend them back, heat the part you are bending with an oxyacetylene torch to make it easier to bend.
Old 11-13-2011, 09:38 PM
I'll try and post some pictures tomorrow.
I question heating the steel to bend, won't I loose some of the strength?
Was hoping to use leverage and do it cold. My guess is I only need to bend them an 1/8" or less at the ends to get the camber correct. Problem will be getting them both correct.
Old 11-13-2011, 09:53 PM
You will not (edit: noticeably) lose strength, as the steel is not heat treated. They're probably bent cold in a giant press at the factory, so there would some work hardening that you'd remove by heating it, but I would not worry about it. If the PO was bending spindles, he was doing something he shouldn't have been.
Something isn't quite making sense here...there is a lot of positive camber in the spindles. If you have negative camber and you only bend them 1/8" the other way, I don't think you'll even approach the original amount of positive camber. Just to make sure you don't have positive and negative camber backwards, negative camber means that the distance between the wheels measured at the top is less than the distance between the wheels at the bottom. Is this what you are experiencing?
Old 11-13-2011, 10:28 PM
Do not heat the part with a torch. All steel (hot rolled or cold rolled) that is used to make parts such as this is "cold worked" during rolling process. That raises the strength.
Forming and shearing during manufacturing further strengthens the part.
ANY heat that will ease the bending will reduce the strength.
The final rolls of steel is done at a low enough temperature to raise the strength. Even if the steel has an oxide layer on it.
Old 11-14-2011, 07:32 AM
No picture but I think I have it backwards. Bottom of wheels are closer so I guess positive camber. How do I measure to see if I'm in tolerance? Tires are old and worn on the outside. Don't want to replace and have them wear out prematurely
Old 11-14-2011, 07:38 AM
ok not familiar with a 149,
but wondering if the axle got put in upside down? that would give a lot of Negative camber.
or the if the camber is in the spindles, if they were swapped/flipped?
Might check out these possibilities before resorting to drastic modification.
You might post some pictures so we can better figure out the problem
Old 11-14-2011, 07:47 AM
cub123's Avatar
cub123 cub123 is offline
It is normal for it to have quite a bit of positive camber, ( bottom of the wheel closer) they came from the factory this way to improve steering. Unless you run it a lot on pavement premature wear won't be a issue, though they will wear a little uneven.
Get us some pictures, it won't be hard to tell if somethings really off.
Old 11-14-2011, 09:48 AM
The wide frames all seem to have a lot of positive camber to make for quick easy steering. My 128 front tires, (originals) were completely wore down on the outside and the insides still looked almost new. Not bad for 40 year old tires. Pics will definitely help a lot.
