Old 11-10-2011, 06:23 PM
Leon renaud Leon renaud is offline
Default help with Throttle shaft repair
I've done a search and can't find what I want I know it's been covered but I can't find it.I need the information,part numbers etc. to repair the throttle shaft holes in the carb.My throttle shaft has some wobble and I want to do the bushing fix on it.Thanks
Leon
Old 11-10-2011, 06:28 PM
krhoover krhoover is offline
http://www.onlycubcadets.net/forum/s...ad.php?t=10329
Try this
Old 11-10-2011, 10:49 PM
Sugarmaker's Avatar
Called a friend and he sent me a custom made bushing for the 147 carb shaft.
I believe the dimensions were .250 I.D. .4375 O.D and about .100 thick. Made of a brass material. Worked great!
I made a mistake and did not allow the butter fly plate to re-seat when I tightened the screws and had to take the carb back off and loosen the screws and allow the plat to get into the fully closed position then re tighten the screws.
Hope this helps,
Regards,
Chris
Casbohm Maple and Honey
www.mapleandhoney.com
Old 11-11-2011, 05:43 AM
Vince_o Vince_o is offline
I get mine from Chris Westfall, he's a sponsor here. They are from Kohler work great, and when you put the screws back in the choke butterfly, I'd use a dab of blue lock tight. You don't want them coming back out and into the intake!
Old 11-11-2011, 06:53 AM
You can also use one of these Kohler Parts...
Old 11-13-2011, 01:06 AM
Thank you all I thought I was looking for very specific repair bushings. I know someone posted with pictures on how to make this repair but I couldn't find that post.
Leon
Old 12-08-2011, 10:24 PM
You can also use one of these...
What brand is this? I've gone to my local Fastenall store and they claim they can not locate either of these part numbers!Sponsors if you cary these shoot me a PM with price for a package of bushings and a dozen screws parts houses near me are a waste!
Old 12-08-2011, 10:46 PM
Check for this part number. I picked them up at my Local Ace Hardware Store.
I used two for the shaft.
They also had the screws for the butterfly plate.
Old 12-09-2011, 06:12 AM
What brand is this?
Kohler
Old 12-13-2011, 02:05 PM
I was just quoted $8.75 each for these bushings and another $9 for shipping!So far I have not found a store here in N.E. Ct. that carries any of these bushings nor wants to be bothered to order them!
