I have the 124 running and mowing :-) Now to start on the 72...
The steel parts of the carb are froze / rusted and the aluminum is corroded. I am wondering if it electrolysis cleaning will work on a carb??? has anyone tried it before? http://onlycubcadets.net/forum/album...pictureid=2356 Thanks |
I am not 100% sure but I would not put the aluminum carb in the electrolysis solution. I think that a 1 gallon pail of gunk carb cleaner would be better suited. You can get that stuff at any auto store. Let it soak for a couple days and it should be a little easier to disassemble.
149,682,1641,1711 with a 12hp in it 1 8" brinly plow 1 10" brinly plow 451 snow blower,H-48 International snow thrower 42" york rake with fold down grader blade. |
Yep, you need carb cleaner. The electrolysis process used here is for ferrous metals only, not aluminum.
The cheaper version of the 1 gallon of carb cleaner is a smaller container of isopropyl alcohol.......$1 vs. $18.
Still don't know what I'm doing in OHIO?.....If you find me, then please point me back toward INDIANA. ![]() |
Both throttle and choke shafts were frozen on the Carter I'm working on on my O. It had sat outside in the NC rain for years. I blasted the shafts with PBlaster 4-5 times over a couple of days then got it to move a couple degrees...blasted more solvent in there... then worked the shaft gently back and forth until I could work it free.
I'd advise that you need to really really really careful removing the butterfly screws or you'll get to explore the drilling out process I'm going thru :-) John
PB pre-treat - DUH!
![]() I use Kroil instead but it will do the same thing in shorter time. I knew there was a simple thing I was missing - non-ferrous dissolves in the electrolysis chemical reactions. Sometimes it becomes evident that I sleep with a Blonde. Thanks Guys ![]() |
Motorcycle guys boil their carbs in water and lemon juice. Looks like it works well, just haven't tried it myself.
http://draftcycleworks.blogspot.com/...green-and.html Randy
2 original cub cadets ![]() 1 100's 2 149's 1 73 1 2182 |
