I have a Cub Cadet Lawn tractor LT 1042, Mfg Date: 12, 2006. Model #
13AX11CG710, Ser. # 1L116H10142. The 747-04307 or 747-04857 Belt keeper Rod came off and got into the blades. In the process it took out two black wires (part in a loom) with a male connector to a female connector that has a bright blue and a white wire coming out of the wiring harness. The wire was probably 12 inches or so; don't know for sure as it was cut. I cannot find any place where the wire should go. The motor will not start, as if the battery is dead. I need to replace the Rod and the wire and I need to know where the wire should connect so the motor will start. Any help? Thanks. |
Here is a link to a PDF you can download of the Service manual. The wiring chart is way down towards the end of the manual. Save the file and print it out.
![]() http://www.imarksweb.net/aws/view.ph...0wMjEwMC5wZGY=
DWayne 1973: 128, ag tires, 3pt. lift, spring assist, lights, 42" Deck 10" moldboard plow 2016 XT1 42" deck 18HP |
Thanks for the reply. It is much appreciated, however I'm unable to open that link. Don't know what I'm doing wrong, but can't seem to get it to work.
Any further suggestions? I really do appreciate your help! |
That's the Information bar right click on that and select download and you'll be set then.
