Old 10-21-2011, 07:52 PM
colt54 colt54 is offline
Default light switch 149
hello all
Did the 149 and the 169 have low and high beam headlights?My original switch has 2 settings but the connectors on the back are broke so the switch is no good I must also add my tail lights were broke too So I got a push and pull switch and new taillights for it (not original)Thank GOD the wires were still good and original on the tractor .Now I have taillights and power for headlights I will have to make a wireharness for the headlights witch is not hard to do,But napa said they have a 4411 headlight for tractors thats high and low beam.So do i need a 3 way switch
Old 10-21-2011, 09:50 PM
No dual beams from the factory, just a single beam. Not sure the S/G could handle High beams. I am sure someone else in here may be able to clear that up. Our sponsors at the top of the page can help you out with an OEM light switch or you could post a wanted add here if you want to go back OEM.
Old 10-22-2011, 01:53 AM
Originally Posted by colt54 View Post
hello all
They misspoke about high and low beams 4411-1 is the GE part number.
Old 10-22-2011, 07:42 PM
GE 4411 is for the screw on type connectors
GE 4411-1 is for the push on type.
Older headlights had 3 connectors for high low beams or...One high and one low beam bulb....
Gee!,no GE...
Up to 530 and counting...
