Old 10-21-2011, 09:43 AM
bdreese27 bdreese27 is offline
Default 100 PTO Engage Lever
I recently picked up a Cub 100 and it is missing the pto engage lever. I can find parts diagrams and the parts but how does it go together? Could someone post a picture or a sketch of how the parts go together on the tractor?
Old 10-21-2011, 11:00 AM
Is this what you are looking for...??
Old 10-21-2011, 05:48 PM
I have found that but I am looking for what hardware mounts the lever to the tractor. How does that all go together with the spring, spacer, what bolt is used?
Old 10-21-2011, 06:03 PM
Here is the hardware for items 4 & 7....
Old 10-23-2011, 03:02 PM
That helps out some. Does anyone have a picture of the assembly mounted on the console of their tractor? I'm still confused as to how the spring works in the assembly.
Old 10-23-2011, 07:04 PM
mmzullo mmzullo is offline
This might help. A picture of my 70(same engagement lever) it has a 3/8 bolt,then washer then lever then spring then goes through the tower and a lock washer and lock nut. I might have better pictures. I think there was a spacer but dont remember.
Old 10-23-2011, 07:55 PM
That helps clear it up a bit. If you have any close up pictures from side angles so I could see what it looks like from drivers seat that would help too.
Old 10-23-2011, 08:25 PM
Here is the one from my nephews 73, hope this helps.
Old 10-23-2011, 08:26 PM
Here's the only rear view I have.
Old 10-23-2011, 09:46 PM
Mike!!
I could comment on that statement butt.....
Here is mine.
There is a spacer in the hole on the handle that keeps it loose.
Up to 534 and counting...
