Old 10-14-2011, 02:03 PM
Kelpie's Avatar
Kelpie Kelpie is offline
Default Mower deck baffle
Hey there,
I have a 38" pin on deck that has a rusted out baffle. Does anyone make these, or should I get one made? I figure the deck would work a lot better with one in place.
BTW, how much noise are these decks supposed to make. Mine is kind of noisy.
1964 Model 70 that Dad bought new. Lights, fenders, creeper, 38 inch deck, Brinly plow, sleeve hitch, and lift assist.
Old 10-14-2011, 05:54 PM
CC1650Dave's Avatar
Your deck will work better with the baffle in place - it helps hold the grass in suspension so the blades can chop it up more before falling to the ground.
They're pretty easy to fabricate and weld into place if you have the equipment. Otherwise, any welding and fabrication shop could do it for you.
Old 10-14-2011, 08:44 PM
brentwd's Avatar
brentwd brentwd is offline
If you will look at my 48" deck that I restored, I built my own baffle for it. The lucky part is I had a small piece to start with. I got the gauge(thickness)from the part and the width. I went to a local shop and they have a slip roll that was big enough to roll a slight curve it the steel. I started with about 10 feet just to be sure I had enough. You will not need that much, but you get the idea. I used 3/4 inch angle to be able to bolt it on and remove if necessary. That is the way it is from the factory. You will have to hand work the metal to make it fit around the blades. I have done 2 and it has worked fine. Hopefully this helps, would be able to answer any Q,s U might have.
