Old 10-13-2011, 01:09 AM
xtreamedrtbker xtreamedrtbker is offline
Default 22x9.5-12 tires on a 147 to lower drive ratio?
I just bought a 147 and I am going mount a blower on it, but I am concerned about the drive ratio being a little too fast. The tractor needs new tires and I
m wondering if its worth going to a 22 inch tire rather then the 23? Would it make that big of a difference?
Old 10-13-2011, 01:16 AM
With a hydro there is no worry over drive ratio. Ease up on that handle a little bit and enjoy life.
I'm going to move this to the attachment section of the site.
Old 10-13-2011, 01:31 AM
Changing the tire size will reduce the speed 4.3%.
Considering the 147 will easily go down to 1 MPH, the tire change will reduce the speed .043 MPH to .957 MPH.
The 23" tires will give better traction, more than offsetting the benefit of speed reduction.
Old 10-13-2011, 03:36 AM
westofb's Avatar
westofb westofb is offline
Plus with the shorter rear tires, your tractor will look like a 50-60's gasser drag car!
Jeff
Brookfield, MO
________________
Old 10-13-2011, 08:03 AM
There shouldn't be a need for worry about speed with a Hydro. I could see a possible need if it was the standard 3 speed. But that is what the creeper drive was designed for.
Old 10-13-2011, 08:53 AM
That probably isn't enough of a change to make a difference in the grand scheme of things because the size on the sidewall and the actual tire height rarely correspond, and there is a lot of variation in height between brands and styles for the same size tractor. A lot of 23" tires are less than 23" tall to begin with anyway.
Old 10-13-2011, 07:17 PM
LarryW's Avatar
LarryW LarryW is offline
I wonder what a normal cub cadet would do with super cub cadet gears? How big of a change is it between those too? Im guessing the gear difference is the same as putting 23" tires on a super?
Cub Cadet 147 2050041u340160
Cub cadet 129 main mower
Cub Cadet 1811
Old 10-13-2011, 07:25 PM
My 1872 Super goes faster, about the same as putting 26s' on a regular.
So I guess they are geared the same!!
Old 10-13-2011, 07:41 PM
They are not geared the same. The hydro pump output shaft has one less gear tooth on it, and the reduction gear is slightly larger as a consequence.
LarryW-
It would be slightly slower. There wouldn't really be a point to making that swap.
