Today I picked up a 1650 with an IH 42" blade, a 50" mower deck, ags and wheel weights. Seems to run pretty well - I'll need to go through it. Photos soon ... had to go all the way to Bailey, CO to get it.
Cheers, Dave ============================================== 1976 1250 Quiet Line/44" Mower Deck 1976 1650 Quiet Line/50" Mower Deck/42" IH Blade Agri-Fab Utility Cart ==============================================
Now you need a 1450 to have all of the QL hydro's.
Sounds like you got a nice 1650 with some good acc.
DWayne 1973: 128, ag tires, 3pt. lift, spring assist, lights, 42" Deck 10" moldboard plow 2016 XT1 42" deck 18HP |
Congrats on the 1650! Can't wait to see your pics.
Alright, here are some photos. Better mechanical shape than the 1250, but in worse cosmetic shape. However, I am apparently ready to push snow in the dark.... and I plan to put a dual-spool valve on it.
Looks like you are ready for the white stuff
Nice looking 1650....boy, those are some giant wheel weights you got with it!
Jeff Brookfield, MO ________________ IH Red 782 with weights and sleeve hitch! IH snow blade, Brinly plow, Brinly disk, Brinly harrow, Johnson rear blade, and a #2 IH Cart |
Nice 1650 and blade.
Congrats on a sweet 1650! Your set for the snow now!
im ready for the white stuff.
Donovan: 62' Original-fenders 63' 100R-K-321a,lights,creeper,electric lift 149-original paint, tiller, three point, duals, ags 1811Custom -M18-18hp kohler magnum, power steering and hydraulic lift with Three point and sleeve hitch. ---------------------------------------------------- Attachments:three-QA 42inch,42inch blade,one-38inch cast end, QA 44inch deck Brinly 12inch plow, 2x cultivators and x2disc Brinly Tool bar cub10:
Thanks, all. Yes, the wheel weights are rather odd - cement filled plastic, one of which seems to be ... ah ... leaking cement. Have to replace those with metal weights at some point, but with the chains that came with the tractor I ought to be good to go for this winter. The hydraulic lift seems to have very little range - might need to add a mechanical multiplier to the lift. I wonder if the way it is set up is correct? Seems the travel of the lift arm on the tractor should translate into a higher range at the plow.
