Hi about a week ago gas started pouring out of my 147's carb. So instead of posting here first i decided to clean the seat and adjust the float and when that did not work i ordered a kohler re buld kit. Now yesterday i re built the carb and re adjusted the float and still gas is pouring out the carb not nearly as much from when i started but it's still not working right.
any help would be really apreciated. |
Was there a new float in it, or can you inspect the float carefully to make sure there's no leaks? Where is the gas leaking from on the carb?
When you did the rebuild did you replace the needle and seat? If they're new it should be closing properly though there may be some junk in between the two now. If there is a hole in the float you would be able to hear gas inside of it when you shake it.
Web Developer - Need a website? Contact me. |
Yes new needle and seat when i drop the bowl there is never any junk on the bottom. The float is fine i feel as if this carb will be the death of me.
check for junk in the bowl vent.
Thanks i figured it out today. When the issue first started i pulled the carb and never checked the float right away but when i re-assembled i did and it was empty. There must have been a hole cause when i pulled it apart tonight the float was full.
Now my next question where do you buy just the float. |
CC Dealer, any other dealer that carries Kohler, the sponsors, ebay, Tulsa engine warehouse, and probably a million other places. Pick your poison...
![]() Quote:
I know Chris Westfall has them for sure, probably all of them could fix you up.
Jeff Brookfield, MO ________________ IH Red 782 with weights and sleeve hitch! IH snow blade, Brinly plow, Brinly disk, Brinly harrow, Johnson rear blade, and a #2 IH Cart |
Congrats! You're almost home free now!
Thanks i just ordered one from him.
