Old 09-29-2011, 09:47 AM
aruss aruss is offline
Default 1650 Hydro problems
Hi all,
I have a 1650 that the drive control started sticking on at about halfway into the forward direction last time I used it. Soon after that it lost drive power on any kind of steep portion of the yard, heard clicking noises when shifting from forward to reverse or moving the drive control through the sticky spot halfway forward to full forward. It was still able to be driven (though slower than usual) when I parked it. I replaced the hydro fluid and filter in the spring of 2010, haven't seen any signs of leaking. Any ideas on what to look for when I tear into this thing?
Thanks,
Andy
Old 09-29-2011, 09:53 AM
Check this link for some ideas:
http://cubfaq.com/trunionrepair.html
http://cubfaq.com/neutraladjust.html
Check all of your hydro linkage to make sure nothing is binding or is excessively worn. To truly get to everything and see what is happening you will need to remove the rear fender pan for easier access along with the tunnel cover.
