im having troubles keeping my starter pully on my 169 tight. i lock tighted both set screws with medium (blue) locktite and that didnt work either.
So do i need to stack set screws on top of each other or would it work to get a longer square key and tap it back so it goes up the ramp part of the crank shaft groove so it tightens? what do you guys think? THANKS
Nick. ![]() Cub cadets 100, 125, 86, 108, 109, 128, 129, 129, 149, 149, 169, 1450, 1650 and a handfull of parts tractors. #40 box blade, ih back blade, rear ih rock rake, #2 cart, windbreaker soft cabs, windbreaker hard cab, cozy cab, kwikway loader , wards corn planter, brinly plows, culitvator, rear blade, disc and the usual decks, snowblowers and 2 tillers |
Nick
On another board, a member had the same problem with one of his. I forget what he used. I will say that Ive pulled a few of those pto/ starter pulleys and some are real loose and others are nice and tight. I'm thinking that if they don't fit snug, maybe they rattle on the crank working the set screws loose. Just thinking here ![]() |
I have in the past used a square key that I beveled to tighten a pulley. I like the idea of stacking the set screws too. How much play is there between pulley and crank shaft? Do you need to use some shim stock?
O _____ O 27670 O 38245 O 49448 100 _____ All W/Fenders, 3 Point, Lights, Brinly Adapter 124 ______ 106 ______ 107 _______ 127 _______ All W/Hydro, 3 Point, Lights, Brinly Adapter 108 _______ W/Factory Electric Lift, 42" Blade, Brinly Adapter 109 _______ W/Factory Electric Lift, 1A Tiller Both/Ext 2 10" plows, Dbl Disk Harrow, Spring Tth Harrow, 2 42" Tool Bars, Box Blade, Yard Sweeper, Aerator 3 Sets Wh wts., Dethatcher, Garden Cart, York Rake(in pieces), Ect... |
I can tighten the pulley up but then it rattles loose a little bit
