Old 09-27-2011, 12:41 PM
tinkerin tim tinkerin tim is offline
Default Will a K321s(electric start) work with a 149 key switch?
I picked up a 149 w/blown engine in May and finally found a replacement. It has the small electric starter. It seems like this would be an upgrade from the S/G set-up but I wonder about the electrical differences. I'm fine with the schematic up to the swich part. Any opinions about S/G vs S would be greatly appreciated.
Thanks
Old 09-27-2011, 01:16 PM
Tim sounds like a QS style engine got a pic of it?
Old 09-27-2011, 03:49 PM
Default 321s for 149
This came out of an Ariens and has a totally different base. I'll swap the oil pan from the 321a. I'll go take a pic in a bit.
Old 09-27-2011, 03:52 PM
I think you'll have to make a new wiring harness for it.
Old 09-27-2011, 04:30 PM
scleve scleve is offline
You would need a wiring diagram from both machines and adapt your harness. Cranking should be straught foward, but the charging circuit could get complicated.
Old 09-27-2011, 04:55 PM
Merk Merk is offline
What kind of oil pan does the Ariens engine have?
If the oil pan is wider than the engine base (where the oil pan bolts to) you will have problems....not worth the aggervation.
It sounds like the Ariens engine has a small starter that runs off the flywheel. The charging system is under the flywheel. You may be able to use a electrical system from a Quiet Line Cub Cadet to make it work if the oil pan is ok.
I have an 86 that is using the electrical system from a Quiet Line Cub Cadet. This 86 is using the same starting-charging system as a Quiiet Line.
Need to see pictures of the Ariens engine.
Old 09-28-2011, 11:22 AM
Default pictures of k321s
I'm not worried about the oil pan. This is a k321 so the oil pans should swap no problem. Here are the pics
tim
Old 09-28-2011, 05:13 PM
by tinkerin tim
The oil pan is a problem. The area below the starter and air filter that is sticking out beyond the side of the block is wider than a engine-oil pan for a Cub Cadet. The oil dipper/slinger may not be long enough to oil the engine. You will have to replace the connecting rod if the oil slinger isn't long enough. There are some who have modified the frame.....you lost any value that the 149 had. There are K321 blocks out there for a Cub Cadet.....I have 3 extras (none for sale before anyone ask).
What is wrong with the block that was in the 149? The black can be reused if there isn't a hole in it.
Old 09-29-2011, 10:29 AM
Default k321s
I had put an edit withe pics but don't know what happened to it. I measured, and the oil pan will not work on the new one. I'm gonna just sell this and look for a 321a. I have a great working 149, so it's not like i'm in a hurry.
One more thing learned the hard way. lol
