My magnum 18 engine in my Cub has a hole in the side of the engine I love the and miss the tractor, even more so after buying a Lowes JD to keep me mowing.
Early this year the motor started blowing oil, if found the govenor shaft was missing. I ordered a new one from the dealer, re installed and noticed the engine was no longer governed. I continued to mow using low throttle, with plans to tear into the engine this winter and fix the govenor. What I did not know is pieces of the govenor were in the bottom of the engine, one eventually got between the crank case and the crank and blew a hole in the engine case. Engine still runs, no knocking. I found a guy that can repair the case, however all threads about rebuilding this engine seem to come to a dead end or have dead links. Can someone please direct me to a thread of a rebuild of this engine? Or a site where I can get the parts to rebuild? I found a dead link with the governor problems these engines are known for, any one have more info on that? Tractor has only 700 hrs. I have no interest in retro fitting a newer style engine, I want to rebuild what I have. Really miss the power steering, and the amazing cut of this tractor |
I believe there is a service manual available that shows you the things you need to do. But i do remember reading a few threads about the M18 rebuilds.
Adrian 2072 (789513) |
The Service Manual you can print out:
http://www.asberry.net/files/TP-2204-B.pdf
DWayne 1973: 128, ag tires, 3pt. lift, spring assist, lights, 42" Deck 10" moldboard plow 2016 XT1 42" deck 18HP |
Governor pinning
![]() Quote:
You just missed a complete engine on Evilpay go for $.99 with a bad rod but good case in Pennsylvania. |
![]() Quote:
Thank you, very helpful! |
Thanks! This was the cause of the problem to begin with
![]() Quote:
Wow, I have been searching for months but I guess I missed that one. Finding a horizontal engine in general is hard enough. |
