Old 09-10-2011, 11:20 PM
Donovan M.'s Avatar
Default 100 PTO ??
How can I get my PTO off my cub 100? I have to do an engine rebuild kit through it. The governor arm came loose and over rev'ed it. It started knocking and were can I get a full engine rebuild kit?
Donovan:
62' Original-fenders
Old 09-11-2011, 08:52 AM
jlampe94's Avatar
jlampe94 jlampe94 is offline
There will be set screws in the holes on the side of the pto itself, normally theres 2 in each hole i think, take those out and from there just try to tap and pull it off, they can be a real pain, it slides off seperate from the pulley for the starter belt behind it. Then you can take that off but be careful because those will bend pretty easy. For an engine rebuild kit if you just want stens parts which i have nothing against ebays the place to get. What all are you looking for in a kit?
Old 09-11-2011, 09:36 AM
Donovan M.
Here are a couple of pictures of what jlampe94 is talking about.
This is the unit you will be trying to remove. You can see one of the set screw holes showing in the picture. And like jlampe94 said there should be 2 set screws in each.
This is a picture of my 169 but yours should look similar. This is the part you don't want to be prying on and bend it up.
Old 09-11-2011, 10:19 AM
Here is a video one of our members put together for PTO removal.
http://www.youtube.com/watch?v=7O4FE1tE_AM
Old 09-11-2011, 07:10 PM
Donovan M.'s Avatar
thank you i still need to get my other set screws out.
Donovan:
Old 09-11-2011, 07:18 PM
Lots of penetrating oil one at a time for a day each if they are stubborn, don't strip out the hex head.
Old 09-12-2011, 10:48 PM
Donovan M.'s Avatar
THANKS for the info
Donovan:
Old 09-12-2011, 11:19 PM
hydrocub hydrocub is offline
the vidio attached shows using WD 40......I highly suggest PB Blaster
or such ....It pays for itself .
