I have a 125 hydro that the pump is shot on, i was wondering if anyone has rebuilt one before and if you did, how you did it and what you got for parts. Any helps appreciated! Thanks ahead of time in case i forget.
In what way is it 'shot'? Considering you can buy a used pump for probably $25, it's not worth trying to fix one unless you have two bad ones to combine into one. Put it on the parts shelf and buy another one...
Well when you try to go forward or back nothing moves, i did the troubleshooting the manuals say to do and that shows that something inside the pump is bad and needs to be rebuilt or so it says. Ive looked at that but havent found any for $25.
I have one, sent you a pm!
Jeff Brookfield, MO ________________ IH Red 782 with weights and sleeve hitch! IH snow blade, Brinly plow, Brinly disk, Brinly harrow, Johnson rear blade, and a #2 IH Cart |
So you checked the relief valves and charge pump pressure? Did you make sure the pin for the charge pump isn't sheared? New fluid and filter?
It is really hard to kill one of these things. I should also mention that if you buy a bunch of new parts to rebuild it, it will cost twice what the entire tractor is worth. |
