Old 08-26-2011, 09:41 PM
FrankF3's Avatar
FrankF3 FrankF3 is offline
Default Diesel Starter Upgrade Question
I have been looking on eBay to find a starter for the starter upgrade. There are so many models, 9 tooth, 11 tooth, CCW, etc. plus multiple models to fit different tractors. Does anyone have starter model that positively worked for the upgrade? I really don't want to buy one and then have to return.exchange it.
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
Old 08-26-2011, 09:49 PM
This is in our Technical Library:
http://www.onlycubcadets.net/forum/showthread.php?t=1
Old 08-26-2011, 10:42 PM
FrankF3's Avatar
Thanks DX3, I'll get it ordered right away.
Old 09-01-2011, 01:05 PM
FrankF3's Avatar
Question
I have just checked on the status of my starters (I ordered 2, one for the 782D and one for the 1572), and they are scheduled for delivery today by the end of day. I was also thinking about performing the glow-plug upgrade. Since the starter has the extra wire coming off of it for power, could I just use this power to run another Ford-type starter solenoid to light the glow plugs at the same time the start is engaged? I could just use the signal for the start solenoid for that matter. What do you think? I know that it would be un-needed then the engine is hot or in warm weather.
Old 09-01-2011, 02:15 PM
Yamaguy's Avatar
Yamaguy Yamaguy is offline
I ordered my starter from a place through Amazon and I hope to have it tomorrow!!! The glow plug mod is next for mine as well!
Dale
147-Restored___________________882 Diesel
Hydro lift (not installed)___________44" Deck
48" Deck_______________________QA-42a/b Snowthrower
Rear lift ________________________XMW cat-0 rear lift
Model 2 tiller____________________12" cat-0 Brinly plow
Old 09-01-2011, 02:21 PM
aagitch's Avatar
aagitch aagitch is offline
Even in warm weather, you'll want the glow plugs to warm unless the engine is already hot. I would think you would drain the battery down and wear out the starter if you were to let the glow plugs warm only when the starter is engaged.
Adrian
2072 (789513)
Old 09-01-2011, 02:53 PM
FrankF3's Avatar
aagitch, even with the glow plug upgrade with the glowplugs that are fast acting?
Old 09-01-2011, 03:48 PM
Yes even with the upgrades, that starting procedure needs to remain the same.
Old 09-01-2011, 04:39 PM
The procedure remains the same, the time required for the glow plugs is shorter. My 782D went from needing about 25 seconds to needing 5-8 after the modification.
If someone wants me to draw a modified 782D wiring diagram for the glow plug mod, I can probably do that.
Old 09-01-2011, 05:00 PM
I would think you wouldn't want to energize the starter and the glow plugs at the same time and place that heavy of a load on the battery. Heat the plugs then energize the starter.
