Old 08-25-2011, 11:06 PM
Default 129 backfire & deck issues
Tonight I was mowing with one of my 129's and it runs as smooth as silk, until you turn the engine off and then it backfires. It has done this before and fouled a plug or two. I had both the low idle screw and fuel inlet screw adjusted to specifications and it backfired hard after about 20 min. of run time, so I opened them both up 1/4 turn and a week later (tonight) it backfired again, but not as hard. So, any recommendations (besides send my tractor to someone...LOQ, ).
Also, when I have the deck down on the lowest setting, the spindles roll to almost a stop and do not cut the grass. If I raise the deck up (3rd notch), then they spin freely. I only have two settings on my deck adjustment, low (1st notch) and high (3rd notch)-which doesn't cut the grass down below about 3 1/2". So, why do my spindles stop and how can I resolve this issue?
Thanks for your helpin advance!!
