Old 08-24-2011, 02:12 PM
wappler-the-cub-man wappler-the-cub-man is offline
Default Cub Cadet 100 Mower issue
Hope you all have some ideas? I have a model 100 with a 3 spindle deck. everything works fine except for the fact that the grass clippings that come out, are the length of the grass:2, 3, or 4 inches. The grass does not get chopped up. Could this be because of no baffle under the deck?
Thanks for any help.
Old 08-24-2011, 02:53 PM
CC1650Dave's Avatar
Yeah, that would cause it. The baffles help lift and hold the grass above the blades so they'll chop it up more. A mulching deck has the baffles all the way around the blade, to create more lift and hold it there longer.
What happened to your baffles?
Old 08-24-2011, 03:40 PM
I've used gator blades and love them! I need to get a set for my 1650! I hate having long grass clippings all over the yard.
Old 08-24-2011, 04:55 PM
Iluvtruks0's Avatar
But with no baffles, would the Gators actually do much better? I love my Gators too, but the baffles are there for a good reason.
David in NC
Old 08-24-2011, 05:07 PM
So true the baffles are a must have. Sorry I wasn't clear on the baffle issue.
Old 08-24-2011, 09:04 PM
I am baffled on the baffles
Old 08-24-2011, 10:38 PM
litlmikeyl's Avatar
litlmikeyl litlmikeyl is offline
I also have a 100 with the 42" 3-spindle deck and have the same issue. Haven't been able to find out if the deck was supposed to have baffles in the first place, and if it did, what they would look like & how they'd mount to the deck. Curious what others have to say about it.
So far I've waited until the grass gets a little long, 6" probably, kept the standard issue (not Gator blades) Cub Cadet/MTD blades sharp, overlapped by roughly a 1/3 of the cutting width to recut the clippings and have had good luck with getting the clippings down to a reasonable size. I usually cut the grass to 3.5" in length. The lawn looks better after I run over it with the tractor alone than when I use my walk behind Toro mulching the grass alone. I'm happy with the results so far so I haven't gotten too bent out of shape about the deck missing the baffles.
Mike - Ramsey, MN
'65 100 - #126432
Options: V61's, 8.5" Tru-Powers, stock sleeve hitch, Xtreme sleeve hitch adapter
Attachments: Dad's 42" Dozer Blade & 38" 3-spindle deck, 42U deck, Homemade Sleeve Hitch Dethatcher & a QA36A Snowthrower
Mods: K301 Upgrade, IHinIN's clutch pivot upgrade, SST driveshaft, custom bar axles
"Why buy something shiny & new when you can save something old."
Old 08-24-2011, 11:05 PM
All of the decks had baffles from the factory that wraps around the back third or so of each blade. Unfortunately I don't have a picture.
Old 08-24-2011, 11:57 PM
CC1650Dave's Avatar
As I understand it, it's all about vacuum. Your deck is creating a suction upward by the rotation of the blades. That's why the high-lift blades like Gators cut clippings finer. And the baffles increase the upward suction by creating a housing around the blade, that will localize the vacuum effect.
So as I said, the mulching decks surround the blade more completely, creating more vacuum.
Old 08-25-2011, 12:10 PM
Thanks fellas, after taking a closer look, it looks like my baffles are rusted away. I f I can't find new ones, I will make some. That could good winter project while checking out rest of deck.
Thanks again.
