Old 08-22-2011, 11:47 PM
Arrowhead's Avatar
Arrowhead Arrowhead is offline
Default Newbie with 124 questions
I picked up a 124 last winter. I finally got time to work on it. I plan on restoring it 100%. I have the 12hp stripped to the block and everything blasted and painted.
Question 1... When I took the clutch off, 3 small clips came off. I don't know how they go back in.
Question 2... I'm wanting to add a 3 point hitch. I see there are several different styles on ebay. I'm thinking the pivoting piece on the center fits between the frame rails where the factory holes are drilled. I see hitches for the narrow frames with a bracket that it pivots on, is that for other models besides the 124?
Question 3... I would like to also add a creeper in the future. Are they all universal? If not, which do I need?
Thanks in advance for any help. I'm really getting into these old Cubs. They were built like tanks.
Old 08-23-2011, 03:08 PM
IHinIN IHinIN is offline
First of all, welcome to OCC Arrowhead.
1. I assume you're referring to the anti-rattle springs on the PTO clutch. A lot of guys leave them out. If you put them back in, the springs go between the friction disc and the basket. It's hard to decribe how they go without a picture. Maybe someone else has a pic showing their placement.
2. You need a narrow frame 3-point setup. The ones with the extra bracket are for the 106-147 series of Cubs. Those would work but you wouldn't need the extra bracket.
3. I believe all of the creeper units are the same although the one for an Original Cub may be different.
Old 08-23-2011, 03:49 PM
mrcubcadet's Avatar
Thumbs up
Here's a link to a thread that has a lot of info and pictures of the PTO, from when another member rebuilt theirs......
http://www.onlycubcadets.net/forum/s...ead.php?t=4489
Hope this helps.
-105___ Tiller
Old 08-23-2011, 06:52 PM
The Original's creeper is totally different, and the handle is different between the NF and WF versions. Otherwise they are the same.
Old 08-23-2011, 11:28 PM
Arrowhead's Avatar
Thanks for the help guys!!
Matt G, excuse my lack of Cub knowledge, but what is NF and WF ? What should I look for when buying a creeper for the 124?
Old 08-23-2011, 11:34 PM
CC1650Dave's Avatar
Narrow Frame and Wide Frame - it denotes generations of IH Cubs.
The Wiki is a decent overview of the IH cubs.
Old 08-24-2011, 10:16 AM
Arrowhead's Avatar
I'm not good with the abbreviations yet. Thanks.
Old 08-24-2011, 10:19 AM
Arrowhead's Avatar
Is the clutch different with a creeper, or just a shorter drive shaft?
Old 08-24-2011, 11:39 AM
The drive shaft is shorter, with a creeper.
