Old 08-04-2009, 08:53 AM
weaverama weaverama is offline
Default 108 - No start
Gentlemen
S/G works well and turns the engiine over fine. I cleaned and gapped points, new plug and checked and cleaned all grounds and contacts. There's no spark at the plug or at the points that I can see.
What's the next step?
I am the mechanically challenged weaverama.
Old 08-04-2009, 09:34 AM
Check for 12V at coil. Also, you may have a bad coil and/or plug wire. Put your ohmmeter across the coil. You should have 3-4 ohms of resistance. If there's no or infinite resistance, the coil is toast.
