Old 08-17-2011, 06:46 PM
lmcclinton lmcclinton is offline
Default Battery backwards
Found that I mistakenly put the neg to the pos and pos to the neg on my CCO. Somehow though, my son managed to get this thing running. Doesn't want to start now. Where do I start to look and what could possibly be "burnt"?
Thanks,
Lee
Old 08-17-2011, 06:58 PM
Won't start or won't turn over?
Old 08-17-2011, 07:47 PM
Won't fire. It has no spark.
Thanks,
Lee
Old 08-17-2011, 08:11 PM
cub cadet people II's Avatar
cub cadet people II cub cadet people II is offline
you probably burnt the points out.
Mike
Way too many!: 4 digit Original’s #1218 and #8820, 70, 71, 72 x2, 73, 86, 100, RESTORED 102,105,122,123,124,125,147 with Danco Loader, 149, 1000, 1572 Diesel with 3 pt, (2) 42” snowplows, 54” Haban Power Angle Blade, (2) 38” decks, (2) 44” decks, (2) 48”decks, #1 cart, #2 cart, #3 cart, #4 cart, Brinly Moldboard plow, Brinly Cultivator, Brinly Disc Harrow,3 sets of IH wheel weights, IH Windbreaker Cab, QA36A blower, QA36 Blower,Boxblade, Giant Vac System off a 73!
Old 08-17-2011, 09:13 PM
Sounds like an error that others might wonder...."How did you make that mistake?", but I recently got a cub where a guy has installed two identical color battery cables and labeled the fender pan + and - (in pencil might I add) to keep from mixing them up!!!! Hope whatever damage you have is minimal!!
Old 08-17-2011, 10:09 PM
what you are describing is preciesly why car salesmen at my dealership were not allow to use the jump boxes ---got a multi meter?
Old 08-18-2011, 05:04 AM
I do have a multimeter but am not the greatest at using it. Ha Ha. It's sorta embarassing but oh well. I have no idea how the heck I reversed the wires not to mention how my son was able to use it. I suppose I'll have to replace the battery to.
Thanks,
Lee
Old 08-18-2011, 06:45 AM
You shouldn't have to replace the battery; it doesn't care what direction it got hooked up, but the coil and condenser do.
Old 08-18-2011, 07:10 AM
No offence Matt,
Actually,
The coil can be hooked up either direction as well as the condenser, so no damage will occur to them.
Years ago many systems used a positive ground.
I would check to see if the voltage regulator is operating correctly, as they can be damaged by reversing polarity.
Chevrolet, in the early days, (when they had wooden floor boards/wheels) had a reversing switch in the ignition system that reversed the polarity of the coil/condenser/points with every start.
Research showed that doing so, increased point life by equally keeping the build up on the contact surfaces equal.
Old 08-18-2011, 07:15 AM
Go to the Tech Library, page #4, and get the wiring diagram. Work your way through the wiring until you discover the issue. The CCO has quite a simple electrical circuit and it shouldn't take long.
I would look primarily in the HV Coil, points, and condenser area.
