Old 08-02-2009, 07:41 AM
deputyrpa's Avatar
deputyrpa deputyrpa is offline
Default 982 w/Power Steering?
So far, I cannot find any reason why I cannot outfit the 982 with power steering. I have the dual spool valve from an 1872 already. A column and a cylinder is all I need to complete the process....oh....and IH Red paint!
Old 08-02-2009, 07:40 PM
aagitch's Avatar
aagitch aagitch is offline
Yes you can use the column and other parts required from a 1872/2072/1772.
Old 08-02-2009, 07:52 PM
deputyrpa's Avatar
I need the steering column and the power steering cylinder....that's it?
Old 08-02-2009, 08:46 PM
You also need the steering knuckle for the left spindle and the lines from the hydro.
Old 08-02-2009, 09:09 PM
deputyrpa's Avatar
Ooooh...the knuckle may be a tough one for me to obtain (not that grabbing the other stuff off eBay is easy or cheap)..... Any suggestions?
Old 08-02-2009, 11:07 PM
murphycc
Guest
Posts: n/a
Cylinder, cylinder mount, spindle is different, and you'll need the clamp on knuckle/lever, hydraulic lines (they are different) and hydraulic 'T' inline. Last steering valve from a 2072 sold on ebay for $336. All parts may run you about $600. Bare in mind you have no garauntee that the used valve will not be a leaker.
FWIW your dual spool has nothing to do with steering, nice feature though.
I could give a link here to a custom steering thread. Please PM me if your interested,
Scott
Old 08-03-2009, 06:16 AM
deputyrpa's Avatar
The spool was sold by the same guy and came off the same tractor. Maybe I should be happy with just an extra set of hydraulic outlets...... I know of the thread to which you speak.
Old 08-03-2009, 04:44 PM
aagitch's Avatar
I'd keep an eye out for a junked super with a blown engine or no engine and maybe you get it the whole thing for a decent price.
Old 08-03-2009, 07:37 PM
ajgross ajgross is offline
Inactive Member
I bet if you rebuilt your steering column and tore apart the front axle, cleaned it, and greased it, you wouldn't think twice about powersteering. I did all of that to my 982 and it steers just as easy as any lawn tractor I've ever owned.
AJ
