Old 07-29-2011, 09:51 PM
TSWolf's Avatar
TSWolf TSWolf is offline
Default 109 won't start
I bought a 109 going on 3 weeks ago, and still haven't got it going yet. I am getting spark and the plug is wet. The points and plug are gapped to .020, and so far I have replaced the coil, head gasket, coil wire, spark plug, and rings. All I can think of is the carb is bad, could this be the case?
Tyler
There are two types of people in this world: those who own cubs and those who wish they did.
I Own:
-1961 Cub Cadet Original
-1972 109
-many other non-cub cadets
Only 18, and already have multiple buildings full of equipment
Old 07-29-2011, 09:59 PM
Your spark plug should be gapped at .035 and you should probably check out this procedure for setting the timing correctly. .020 point gap might not work with your motor.
http://mgonitzke.net16.net/tools/static_timing.pdf
