Thread Tools
Display Modes
I think i have a bad key switch its 3 prong terminal when i test with my ohms meter i connect one lead to the battery prong of the key switch and i have no continuity to the ignition side of the terminal or any terminal i maybe be checking this switch wrong or is it bad and does anyone know of a good sorce to get a good keyswitch for a early model cub cadet 107 thanks in advance for any help
Are you testing the functionality of the switch with the key in each position? If it is off, there will be no continuity anywhere. Battery and I are connected with the switch on, battery is connected to both I and S when the switch is in the start position. A CC dealer or the sponsors will have a new switch.
yea when i grounded the switch i had power the puzzleing part is when i put the key switch in the crank position it does not have power the the ignition side baiscly i am starting from scratch on my wiring my switch may be good and im just wiring it wrong
New switch?
You need to find a key switch that is for a battery ingition system. The replacement stens switches are design for a magneto system. The only place I can find a 3 prong battery ingition key switch is a Cub Cadet dealer. Best thing you can do is buy a new wire harness. You will be father ahead In the long run. |
